Groundplane automatic to -0.001 lower than bounding box PLEASE :)
Guys, all I want for Christmas is a groundplane that doesn’t show through the material of a plane, so could you please adjust it so it automatically is poitioned 0.001 BELOW the objects boundingbox?
Or add an option to position it X units LOWER than the objects in the Groundplane dialogbox, but I guess that will be a wish for Rhino 7 since the UI of V6 is locked as far as I know.
Cheers
+1. Maybe a minimal offset should be default under the hood to avoid zfighting.
Logged request for offset to automatic GP height:
https://mcneel.myjetbrains.com/youtrack/issue/RH-50077
FWIW Raytraced already slightly offsets the GP before tracing it (:
Excellent! How much do you offset it? The distance of the file tolerance, or more?
(I guess using the same value for OpenGL as Raytraced would make sense)
@Holo The display is already applying a bias to the GP … can you please post an example that shows the Z-Fighting between plane and objects…
Thanks,
-Jeff
Hi Jeff, I see that it works fine on new files now (not on the same machine though) so maybe I sat groundplane to fixed at 0 on that file… I’ll see if I can relocate the file when back at the office and I’ll check new files on that machine.
Ok, I see this if I make a large mesh that is far from origin.
MeshFlickerGroundPlane.3dm (66.6 KB)
Hm… that happens when 1/10 the size just above origin too…
Can you check to see if you get the same flickering on your system?
MeshFlickerGroundPlane2.3dm (91.6 KB)
Edit:
but if I make it another 1/10 the size then the flicker disappear.
So maybe the automatic offset needs to be 1/xxx of the boundingbox size and not a fixed value?
