Just realised the automatic ground plane doesn’t include 2D objects. So if I have a 2d object below any 3d objects, they get hidden underneath the ground plane. Is there a way to change this?
Hi Andrew - we have this issue on our list as item RH-50734.
Currently, the only ways around this are to either use a display mode without the ground plane or to manually lower the ground plane in the display mode settings.
Thanks Wim! Good to know it’s not the buglist.
