If you have the groundplane set to 0.0 always then objects below that won’t show when looked at from above the ground plane. But noce you are below the groundplane you will see objects that are there. That is how it is supposed to work.
Ah, I get it now, you are expecting to see linework as well. That won’t work. The automatic groundplane looks only at objects that generate render meshes. From our docs on groundplane:
Automatic
Turns on auto-elevation that moves Ground Plane to the lowest point of the objects in the model. New objects added to the scene may change Ground Plane elevation. Auto-elevation ignores non-meshable* object types.
*Non-meshable object types do not generate render meshes. For example, curves, dimensions, texture mapping widgets, etc.
Since you have automatic elevation checked the groundplane will be at the lowest point of all objects that generate these meshes.
You should switch off the automatic altitude and move your geometry to the 0-plane.
