Grasshoppper ~ Extrude to plane
THIS ought to be simple. I created the Brep extrusion (coloured purple) in Rhino, but I’m trying to achieve a similar result in Grasshopper, using Extrude-to-Plane (ex-Sasquatch).
It fails but I cannot see why it should fail.
Any ideas? Please?!
Extrusion Test—08a (boxes combined) copy.3dm (2.9 MB)
Extrusion Test—08a (Extrusioning)— copy.gh (21.1 KB)
Rhino 7.36 | OSX Mojave | 2012 Mac Pro
missing
That’s an extraordinarily complicated way to create a plane! And I’m genuinely surprised that there is no GH method for projecting a curve to a plane with an arbitrary vector instead of the plane’s Z?
So this got more complicated than I expected.
Extrusion_2024Feb14a.gh (21.7 KB)
Extrude to Planne v0.gh (7.6 KB)
Make it an UserObject.
Of course, thank you :exclamation: The standard ProjectA (Project Along) component.
I don’t think I’ve ever used it so didn’t even see it. This is how simple I expected it to be. Geometry is internalized, no need for Rhino file.
Extrusion_2024Feb14b.gh (6.2 KB)
P.S. @clivecarter the construction plane in your Rhino file appears to be angled? Annoying,
PLANE complication ~ in order to focus on the (apparently non-functional-) Component, the Gh file I uploaded is a cut-down version of a bigger Definition. The plane(s) represent basic sides of entities in a project where I want to be able to adjust them later on. It seems that this Component does not live up to its straightforward title …
THIS all works; thank you much for looking at this Joseph—and Quan Li.
I remain perplexed as to why the Sasquatch Component, having such a hopeful, straightforward title, did not work. But I can now move on …
