In this 15-minute Grasshopper Voronoi Pattern tutorial, you will learn to produce a Voronoi Pattern based on sunflower seed distribution.
The technique uses the Maelstrom component to twist a series of straight lines to produce the Voronoi cells. It’s not the actual Fibonacci sequence but it’s a quick trick you can use to produce a pattern similar to it.
This is just one of a series of courses by Parametric House that you can enroll in.
Voronoi Pattern tutorial by Parametric House…
Posted Jul 09, 2019 by Sandy McNeel on Rhino News, etc.
