There seems to be some discrepancies between Sweep1 output when using it from Grasshopper, from grasshopper using RhinoCommon in a C# component and from Rhino directly.
Attached is an example. (tolerance in the Rhino file I am trying this in is the same as what is set in the c# component)
SweepBug.gh (11.3 KB)
Just to document what is happening on my side:
- Input rail and profile
- Sweep1 from grasshopper gives an error
- Sweep1 using rhinocommon from a c# component
After aligning the seam of the rail to the position of the profile, - Sweep1 from grasshopper outputs untrimmed surfaces
- while Sweep1 using rhinocommon from a c# component, gives the desired output which is similar to running sweep1 in rhino on the same rail and profile.
