I am trying to import multiple meshes with rhino3dm & grasshopper script (with proper input). However - when I construct the meshes, pack them into array and send as encoded values - the grasshopper fails to run because of invalid arguments provided (array instead of object). Can I somehow enforce array items casting to proper type such a mesh? What am I doing wrong?
The grasshopper file is 100% valid as without external input it works just fine.
My procedure:
- Create several Rhino.mesh instances from rhino3dm in nodejs script
- Call the definition solve with proper params (passing the data as:
inputs: {
mesh: JSON.stringify([ rhinoMesh1.encode(), rhinoMesh2.encode(), rhinoMesh3.encode() ])
- Receive an error described above.
