Sebas
(Sebas)
March 2, 2023, 10:17am
1
I’m using threejs to load some scan, but I want to send that geometry to Rhino compute with the GH definition using the component Get Geometry.
Anyone know how I have to parse my data from Threejs to send to that component?
I’m doing like that in my ts code:
// Convert Three.js mesh to Rhino mesh
const response = await this.rhinoService.solve(
value: 0
value: this.mesh.geometry
Really thanks
fraguada
(Luis Fraguada)
March 2, 2023, 11:51am
2
You can do this with the rhino3dm.js library:
const rhinoMesh = rhino.Mesh.createFromThreejsJSON( { data: mesh.geometry } )
Where mesh is a threejs mesh.
See: rhino-developer-samples/script.js at 7 · mcneel/rhino-developer-samples · GitHub
Sebas
(Sebas)
March 2, 2023, 2:17pm
3
Hi Luis,
I’ve tried that but wihout luck, It looks like the conversion to rhino mesh works:
But I still get the error on the rhino compute:
More code:
Blockquote
name: “Elevar Arco Interno”,
value: this.productGenerator.archModification
value: “Test \n test \n 1 \n 2”
name: “Tipo De Agujeros”,
value: 1
value: 0
value: rhino.Mesh.createFromThreejsJSON( { data: this.mesh.geometry } )
const responseJson = await response.json();
Solve function
async solve(inputs: { name: string, value: any } ) {
compute.url = “http://localhost:8081/ ”;
compute.apiKey = “”;
let GrasshopperFile = “https:xxxx.gh”;
// this.firstVersion.map((input) => {
// this.addDataTree(input.name, input.value);
inputs.map((input) => {
const RhinoResponse = await compute.Grasshopper.evaluateDefinition(GrasshopperFile, this.trees, false);
console.log('Received response from server:', RhinoResponse);
return RhinoResponse;
addDataTree(key, value): void {
let param = new compute.Grasshopper.DataTree(key)
param.append([0], Array.isArray(value) ? value : [value])
this.trees.push(param)
fraguada
(Luis Fraguada)
March 2, 2023, 2:43pm
4
You still need to format the result. Look at this example: rhino-developer-samples/script.js at 7 · mcneel/rhino-developer-samples · GitHub
convert from threejs to 3dm and encode:
const rhinoMesh = rhino.Mesh.createFromThreejsJSON( { data: mainSphere } )
const rhinoMeshData = JSON.stringify( rhinoMesh.encode() )
prep to send to compute:
// format data
let param1 = new RhinoCompute.Grasshopper.DataTree('mainMesh')
param1.append([0], [rhinoMeshData] )
// Add all params to an array
let trees = []
trees.push( param1 )
send to compute
const res = await RhinoCompute.Grasshopper.evaluateDefinition(definition, trees)
Sebas
(Sebas)
March 2, 2023, 3:20pm
5
Hi @fraguada , it looks now is doing somehting,
But I’m getting other erros:
When I use directly an stl from the local directory on grasshopper that doesn’t happens, and I’m loading the exact same file, but when I send it from threejs it fails and generates something weid:
Threejs result(with error, the object it’s strange because it finishes with errors)
Normal functionality:
What can cause that?
I think the mesh is not arriving correctly to rhino/GH because it’s generating this result because the mesh is empty.
Really appreciate your help!
fraguada
(Luis Fraguada)
March 2, 2023, 8:55pm
6
I’d need some sample geometry to attempt to diagnose this.
Sebas
(Sebas)
March 3, 2023, 6:27am
7
For sure,
Maybe the problem it’s because I use STL instead OBJ?
I’ve tried to just return the same mesh, ignoring the other processes and it still fails.
I attach you the STL
stl_convert.stl (1.9 MB)
Sebas
(Sebas)
March 25, 2023, 3:13pm
8
Hello Luis,
Is that failing because i’m loading an STL instead OBJ?
Really thanks
fraguada
(Luis Fraguada)
March 27, 2023, 1:53pm
9
You should be loading the STL with the Three js STL Loader .
Please provide a simplified version of the code you are developing so we can see where it might be going wrong.
Sebas
(Sebas)
March 28, 2023, 10:35am
10
Hello Luis,
I’ve tried something, send directly the sphereGeometry created on your exmaple and it works great, but if I save that STL in some file, and then I load id from that file, when I send it to the server, the server just instantly crash without any type of error:
This is how I load my STL files:
loader.load(data.uri, (geometry) => {
let material = new THREE.MeshPhongMaterial({ color: 0xF1C27D, transparent: false, side: THREE.DoubleSide, clippingPlanes: this.clippingPlanes, flatShading: false });
this.mesh = new THREE.Mesh(geometry, material);
this.mesh.name = ‘loaded_file’
this.mesh.receiveShadow = true;
this.mesh.castShadow = true;
this.mesh.matrixAutoUpdate = true;
this.renderer.localClippingEnabled = false;
this.scene.add(this.mesh);
}, (onprogress) => {
}, (err) => {
The result of mesh.geometry from mainSphere (without loading the STL)
The result of mesh.geometry when I load from the STL file (Same geometry (the sphere))
In that case the server just crashes with that simple geometry(Sphere)
I think it’s because it’s a BufferGeometry?
I attach the sphere STL file.
sphere_saved.stl (97.0 KB)
Sebas
(Sebas)
March 28, 2023, 8:47pm
12
Hello Luis,
Correct, in that way works perfectly, but not when I save the sphere in STL and then load it and I send the mesh.geometry.
In your side it’s working?
fraguada
(Luis Fraguada)
March 30, 2023, 7:59am
13
Are you using the STLLoader ?
Sebas
(Sebas)
March 30, 2023, 8:06am
14
Hi Luis,
Yes, I’m using:
import { STLLoader } from ‘three/examples/jsm/loaders/STLLoader’;
fraguada
(Luis Fraguada)
March 30, 2023, 9:45am
15
Can you share your definition? I am having a difficult time debugging this. Passing the loaded stl without doing anything in GH works fine. As soon as I try to add anything else, even something as simple as adding some vertex colors causes Rhino.Compute to crash. If you can share your definition I can work with @AndyPayne to see where things are going wrong.
Sebas
(Sebas)
March 30, 2023, 9:47am
16
For sure,
It’s so simple, I attach you the GH definition.
Really thanks for helping me on that!
basic_test.gh (20.7 KB)
