Grasshopper / Rhino crashes when pulling cables while holding shift (also when hitting shift+ shift~) [SOLVED]
Hi.
So i observed that grasshopper crashes ALWAYS when doing the following. Somebody experiencing this as well? Any idea what it could be?
shift +
shift ~
shift plus pulling cables (adding additional cables)
… and shift plus delete…
// shift in general.
OK ( @enric )
the BUBBLE Plugin is causing this. it uses shift to blend in a info tool box.
Hi @anika.boeller,
I’ve just published Bubble 3.0 WIP24, that fixes this bug. You can download it from:
http://www.asuni.com/portfolio/bubble-for-rhino/
Regards,
Enric
