Unless I do something really stupid most of the time grasshopper is a very stable programme, but on one code I have created it seems to keep crashing for no reason when I edit a slider etc. I have a feeling it due to a bug/issue with offset surface and offset surface loose components.
Just added a Shrink Trimmed Surface component before the offset surface to see if this solved it.
I can’t post the code here but if someone in McNeel is interested I can email it. Also next time it happens I will file the crash report that pops up after rhino closes.
Also having issues with crazy Sweep 2 outputs that work in rhino fine, but that’s a different matter in the same code.
