Rhino Script Editor does not open
Both the Rihno Scipt Editor and the Python Editor do not open
Rhino 8 Version (8.0.22214.12305, 2022-08-02) (they work fine with Rhino 7)
this is what i tried so far:
I reinstalled Rhino 8
i deleted all files under C:\Users%myusername%\AppData\Roaming\McNeel\Rhinoceros\8.0 - they have been recreated and set to default
I did not install a different IronPython
RhinoCode does work as expected
what else can i do to make it work?
Hi Ralph -
That seems to be working fine here.
A new version was released yesterday. Could you please update to that version and try again?
Hello Wim
New Version 8.0.22221.12305, 2022-08-09 - still not working.
-Ralph
Thanks for checking that, Ralph.
Could you try a “Repair” of the Rhino installation from the Windows Control Panel?
(Control Panel\Programs\Programs and Features)
Did not help, thank you for looking into it, i have two Monitors, but the editor windows do not appear at any of it, although, is there a way to reset the window position, just a thought, maybe its set to something strange?
I suppose it’s worth a try. There is the testResetWindowPositions command that would do that.
hm - did not help.
New Version of Rhino 8 (8.0.22263.16305, 2022-09-20) - python editor and Scripteditor still not working, at least there a some error messages:
Command: _EditPythonScript
[PlugIn::Create] Start
  plugin_name = IronPython
  Looking for plug-in's GuidAttribute
  Created PlugIn Instance
[PlugIn::Create] Finished
Building Python dynamic commands
  dir = C:\Users\ralph\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\PythonPlugins
Exception caught during RunCommand
System.ArgumentException: Requested value 'Ctrl' was not found.
   at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan`1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result)
   at System.Enum.TryParse(Type enumType, ReadOnlySpan`1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
   at System.Enum.Parse(Type enumType, String value)
   at System.Windows.Forms.KeysConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
   at System.Resources.Extensions.DeserializingResourceReader.DeserializeObject(Int32 typeIndex)
   at System.Resources.Extensions.DeserializingResourceReader.LoadObjectV2(Int32 pos, ResourceTypeCode& typeCode)
   at System.Resources.Extensions.DeserializingResourceReader.ResourceEnumerator.get_Entry()
   at System.Resources.Extensions.DeserializingResourceReader.ResourceEnumerator.get_Current()
   at System.ComponentModel.ComponentResourceManager.FillResources(CultureInfo culture, ResourceSet& resourceSet)
   at System.ComponentModel.ComponentResourceManager.ApplyResources(Object value, String objectName, CultureInfo culture)
   at System.ComponentModel.ComponentResourceManager.ApplyResources(Object value, String objectName)
   at RhinoDLR_Python.ScriptForm.InitializeComponent() in D:\BuildAgent\work\dujour\src4\rhino4\Plug-ins\ironpython\plugin\Forms\ScriptForm.Designer.cs:line 191
   at RhinoDLR_Python.ScriptForm..ctor() in D:\BuildAgent\work\dujour\src4\rhino4\Plug-ins\ironpython\plugin\Forms\ScriptForm.cs:line 153
   at RhinoDLR_Python.EditPythonScriptCommand.ShowEditor() in D:\BuildAgent\work\dujour\src4\rhino4\Plug-ins\ironpython\plugin\IronPythonCommand.cs:line 217
   at RhinoDLR_Python.EditPythonScriptCommand.RunInteractive(RhinoDoc doc) in D:\BuildAgent\work\dujour\src4\rhino4\Plug-ins\ironpython\plugin\IronPythonCommand.cs:line 202
   at RhinoDLR_Python.EditPythonScriptCommand.RunCommand(RhinoDoc doc, RunMode mode) in D:\BuildAgent\work\dujour\src4\rhino4\Plug-ins\ironpython\plugin\IronPythonCommand.cs:line 62
   at Rhino.Commands.Command.OnRunCommand(Int32 commandSerialNumber, UInt32 docSerialNumber, Int32 mode)
   Command: _EditScript
  plugin_name = RhinoScriptEditor
   at ScriptEditor.Forms.MainWindow.InitializeComponent()
   at ScriptEditor.Forms.MainWindow..ctor()
   at ScriptEditor.Forms.MainWindow.get_TheMainWindow()
   at Commands.CmdEditScript.RunCommand(RhinoDoc doc, RunMode mode)
hi
I have the same problem
Rhino 8 SR0 2022-9-20 (Rhino WIP, 8.0.22263.16305, Git hash:master @ c00f59a1d109938b86d1d17b6a2d2409668290a0)
License type: Commerciale, build 2022-09-20
License details: Cloud Zoo
Expires on: 2022-11-04
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.94
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\Riccardo\Documents\Rhino Risorse\rptooltoolbar\rptool.rhp “RP_Tool” 0.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\22.3.0.0\bella_rhino.rhp “Bella” 22.3.0.0
C:\Users\Riccardo\Google Drive\Progetti VS2015\Aura Script\aurorajewels\AuroraJewelsTools7.rhp “AuroraJewelsTools7” 7.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ElefrontProperties (5db9285b-b408-41e2-b815-ed6ad84fd4a9)\1.0.0.0\Rhino 6\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\Riccardo\Google Drive\Progetti VS2015\RhinoJobs\bin\RhinoJobs.rhp “RhinoJobs” 1.0.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoScriptEditor.rhp “RhinoScriptEditor” 8.0.22213.0
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\Constraints.rhp “Constraints”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.22263.16305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.22263.16305
it works if i set my Windows 10 language from german to english
Hi Ralph -
Thanks for that additional information.
Are you also running Rhino in German, or is that set to English?
Riccardo (@mix_experience) , are you running Windows and/or Rhino in Italian?
I run Rhino in English, but changing to German does not change anything in that respect
I run Rhino in English and win 11
@mix_experience , you run Rhino in English but is your operating system (win 11) also in English?
I don’t know if that makes a difference. I’m just trying to find a pattern.
win11 in italian
Hello
I did some tests with “net core” if I open rhinoscript appears this message :
Looking for plug-in’s GuidAttribute
System.ArgumentException: Requested value ‘Ctrl’ was not found.
at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) at System.Enum.TryParse(Type enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
at System.Resources.Extensions.DeserializingResourceReader._LoadObjectV2(Int32 pos, ResourceTypeCode& typeCode)
at ScriptEditor.Forms.MainWindow…ctor()
while and use net framework does not open anything without essun message
Thanks for the info. The issue is logged.
it is working now (8.0.22291.12305, 2022-10-18), thank you very much
hi Ralph i have the same issu with script editor (not working) it would be great if you tell me the solution that you used… I need it sooo much. thanks
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
