Grasshopper loading errors
Hi there,
I’m having a problem with starting Grashopper on Rhino 8.
Several tools can’t be loaded, see below.
In the WIP there were no probems like that, didn’t uninstall that version but I simply registered the new license. What may be wrong?
The text message at the start:
Details
Object: ProfileClosestPlaneComponent (level 1)
The type initializer for ‘’ threw an exception.
TypeInitializationException
Object: ProfileClosestPlaneComponent (level 2)
This assembly is protected by an unregistered version of Eziriz’s “.NET Reactor”! This assembly won’t further work.
Exception
Object: ReplaceFeatureComponent (level 1)
Object: ReplaceFeatureComponent (level 2)
Exception
Object: RemoveFeatureComponent (level 1)
Object: RemoveFeatureComponent (level 2)
Exception
Object: EditProfileMiterComponent (level 1)
Object: EditProfileMiterComponent (level 2)
Exception
Object: DeconstructSection2DComponent (level 1)
Object: DeconstructSection2DComponent (level 2)
Exception
Object: DeconstructProfileComponent (level 1)
Object: DeconstructProfileComponent (level 2)
Exception
Object: CreateSection2DComponent (level 1)
Object: CreateSection2DComponent (level 2)
Exception
Object: CreateProfile3DmiterComponent (level 1)
Object: CreateProfile3DmiterComponent (level 2)
Exception
Object: CreateProfile3DdefComponent (level 1)
Object: CreateProfile3DdefComponent (level 2)
Exception
Object: APEVoidComponent (level 1)
Object: APEVoidComponent (level 2)
Exception
Object: APEHoleSteppedComponent (level 1)
Object: APEHoleSteppedComponent (level 2)
Exception
Object: APEHoleRegularComponent (level 1)
Object: APEHoleRegularComponent (level 2)
Exception
Object: APEHoleCountersunkComponent (level 1)
Object: APEHoleCountersunkComponent (level 2)
Exception
Object: AddFeatureComponent (level 1)
Object: AddFeatureComponent (level 2)
Exception
Object: Section2DParam (level 1)
Object: Section2DParam (level 2)
Exception
Object: Profile3DParam (level 1)
Object: Profile3DParam (level 2)
Exception
Object: FeatureParam (level 1)
Object: FeatureParam (level 2)
Exception
Object: TextObjectComponent (level 1)
Object: TextObjectComponent (level 2)
Exception
Object: TextDotComponent (level 1)
Object: TextDotComponent (level 2)
Exception
Object: ReadDimStylesComponent (level 1)
Object: ReadDimStylesComponent (level 2)
Exception
Object: RadialDimensionComponent (level 1)
Object: RadialDimensionComponent (level 2)
Exception
Object: OrdinateDimensionComponent (level 1)
Object: OrdinateDimensionComponent (level 2)
Exception
Object: LinearDimensionComponent (level 1)
Object: LinearDimensionComponent (level 2)
Exception
Object: LeaderComponent (level 1)
Object: LeaderComponent (level 2)
Exception
Object: AngularDimensionComponent (level 1)
Object: AngularDimensionComponent (level 2)
Exception
Object: ApeInsertBlockComponent (level 1)
Object: ApeInsertBlockComponent (level 2)
Exception
Object: ApeExplodeAttributesComponent (level 1)
Object: ApeExplodeAttributesComponent (level 2)
Exception
Object: ApeDefineBlockComponent (level 1)
Object: ApeDefineBlockComponent (level 2)
Exception
Object: ApeDeconstructBlockComponent (level 1)
Object: ApeDeconstructBlockComponent (level 2)
Exception
Object: ApeCreateAttributesComponent (level 1)
Object: ApeCreateAttributesComponent (level 2)
Exception
Object: ApeBlockListComponent (level 1)
Object: ApeBlockListComponent (level 2)
Exception
Object: ApeLicenseComponent (level 1)
Object: ApeLicenseComponent (level 2)
Exception
Object: ApeAuthorComponent (level 1)
Object: ApeAuthorComponent (level 2)
Exception
Object: ApeSparkExportVoxComponent (level 1)
Object: ApeSparkExportVoxComponent (level 2)
Exception
Object: ApeObjectAttributesComponent_OBSOLETE (level 1)
Object: ApeObjectAttributesComponent_OBSOLETE (level 2)
Exception
Object: ApeInputComponent (level 1)
Object: ApeInputComponent (level 2)
Exception
Object: ApeObjectComponent (level 1)
Object: ApeObjectComponent (level 2)
Exception
Object: ApeSparkBakeComponent (level 1)
Object: ApeSparkBakeComponent (level 2)
Exception
Object: ApeSparkExportCsvComponent (level 1)
Object: ApeSparkExportCsvComponent (level 2)
Exception
Object: ApeSparkExportTxtComponent (level 1)
Object: ApeSparkExportTxtComponent (level 2)
Exception
Object: ApePublisherComponent (level 1)
Object: ApePublisherComponent (level 2)
Exception
it looks like you are trying to load a plugin that is not compatible with .NetCore, try switching your Rhino 8 to .Netframework to troubleshoot.
Thanks for fast reply.
But the command SetDotNetRuntime is told to be an unknown command.
Now it’s becoming a little strange, Rhino8 won’t start at all with the .Net installed, right?
Running aggressive antivirus software? you may need to disable or allow Rhino to install.
Lets do a repair install and try again (via Add or Remove programs>Modfy>Repair install
Please run systeminfo in the Rhino command line and post the results.
Now I read the end of the detail list message. It’s about the Rhenso Adaptive Parts app, I can’t load it, can’t also find it to uninstall. Not in the Rhino Plugins List, not in Windows…
How did you originally install it? Try via the Package Manager or add remove programs first.
Here is more details and their contact info
https://www.food4rhino.com/en/app/adaptive-parts-environment?page=3&lang=de#commentsSection
Thanks,
that worked. I ran the repair installl for Rhino and then the package manager to uninstall the Adaptive Parts. No more messages at the start of Grasshopper.
