Hi All,
I’m working on a Grasshopper plugin and I’d like to target both Rhino 7 and Rhino 8, so I’m targeting the 7.21.22208.13001 version of the Grasshopper and Rhino SDK.
I’ve created a yak package with the following structure:
├── .gitignore
├── manifest.yml
├── net48/
│ ├── Newtonsoft.Json.dll
│ ├── System.Buffers.dll
│ ├── System.Memory.dll
│ ├── System.Numerics.Vectors.dll
│ ├── System.Resources.Extensions.dll
│ ├── System.Runtime.CompilerServices.Unsafe.dll
│ ├── TapirGrasshopperPlugin.gha
│ └── TapirGrasshopperPlugin.pdb
└── net7.0/
├── TapirGrasshopperPlugin.deps.json
├── TapirGrasshopperPlugin.pdb
└── TapirGrasshopperPlugin.runtimeconfig.json
When I drag&drop the yak file in Rhino 8 everything works fine. After a restart I can see my plugin in Grasshopper.
But when I do the same in Rhino 7 everything seems fine, I get this message:
Command: _-PackageManager
Choose option ( Search ): _Install
Package file: "C:\tapir-archicad-automation\grasshopper-plugin\YakPackage\tapir-1.0.9-rh7_21-any.yak"
Successfully installed Tapir (1.0.9)
The problem is that when I open Grasshopper I can’t see my plugin. Not even after a Rhino restart. If I just copy the files from the net48 folder to the Components folder it works.
What could be the issue here?
