I was wondering if someone might be able to help me with an installation problem. I am using Rhino 4.0 SR9 and have downloaded the old grasshopper edition. The program shows up in C: and when I go to options > rhino options > plugins it shows up but says it is not loaded automatically. When I try to load it manually it still does not work because of the error message listed below. I have also tried all the other easy basics like reinstalling grasshopper a second time, dragging the plugin into Rhino, typing grasshopper into the command line…
Anyways, when I try using grasshopper, I get the following error:
"Exception occurred in plug-in Grasshopper
Unable to Load DLL ‘rhcommon_c’: The application has failed to start
because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. (Exception from HRESULT: 0x800736B1)
Stack trace:
at
UnsafeNativeMethods.ON_UserData_RegisterCustomeUserData(String
managed_type_name, Guid managed_type_id)
at Rhino.Runtime.HostUtils.initializeRhinoCommon()
at Grasshopper.Plugin.GH_PluginUtil.LoadGrasshopper() in
C:\dev\Grasshopper\1.0\root\src\GH_GrasshopperPluginUtil.vb:line 33
at Grasshopper.Plugin.GrasshopperPlugin.OnLoadPlugIn()
at
RhDN_NativePlugInBase<CRhinoUtilityPlugIn,RMA::Rhino::MRhinoUtili
tyPlugIn>.OnLoadPlugIn(RhDN_NativePlugInBase<CRhinoUtilityPlugIn
,RMA::Rhino::MRhinoUtilityPlugin>*)
Thanks in advance for the help and suggestions!
Alyssa
