Rhino8 + Grasshopper “Error occured Loading PlugIn” as of Update (8.4.24044.15001, 2024-02-13)
Hi Brains Trust
I recently updated Rhino8 to 8.4.24044.15001, 2024-02-13 (on the 26th/2nd) and since then Rhino8 has been loading in with “Error occured Loading PlugIn” and unable to boot the Grasshopper PlugIn.
Command line reads:
> Command: _Grasshopper
Could not load file or assembly 'C:\Program Files\Rhino 8\Plug-ins\Grasshopper\Grasshopper.dll'. The system cannot find the file specified. Error occurred loading plug-in Details: Could not load file or assembly 'Grasshopper, Version=8.4.24044.15001, Culture=neutral, PublicKeyToken=dda4f5ec2cd80803'. The system cannot find the file specified. ---- GrasshopperPlugin ==== at GrasshopperPlugin.GrasshopperPlugin.OnLoad(String& errorMessage) at Rhino.PlugIns.PlugIn.InternalOnLoad(Int32 pluginSerialNumber) ---- Unknown command: _Grasshopper
I can confirm that grasshopper was working in Rhino 8 Prior to the update and still works in Rhino 6.
I was wondering in anyone was experiencing a similar issue or had some advice on resolving it.
Thanks
M
