Grasshopper not displaying plug-ins and user objects
Since the latest update of Rhino 7, GH does not display all my installed plug-ins and starts with blank tools
I verify that the libraries are there and everything is there, but the tools are not accessible anymore
these are the plug-ins I use:
And not only plug-in some standard components are not available anymore:
Any idea what’s going on?
Thank you
Hi -
Are you getting any error messages while Grasshopper starts?
Have you tried repairing the Rhino installation?
HI, I do not get any error messages. Nor repairing the installation, I’ll try that
Thank you
So I did install the latest build and I get the same problem. I’ve also try the installer itself but there is no repair option. Its just tells me that my installed version is newer then the installer.
Any help would be much appreciated
Thank you
This is really weird, the components are there as I can search for them but not visible on the tools bar
And an other strange behavior, the search box in GH gives me this:
Hi -
The repair option should be available when you right-click Rhino in the Windows Control Panel > Programs > Programs and Features list and pick Change:
That was going to be my next question. I assume that they work as expected when you search for them and put them on the canvas? Like, for example, the Unit X (vector) that I see is missing from your ribbon?
How is that search box different from the one in your previous post?
At any rate, I would recommend trying to isolate the issue by disabling non-standard plug-ins.
You can do this by restarting Rhino and then running the GrasshopperLoadOneByOne command.
Start with only allowing standard Grasshopper parts. If that works, try allowing one plug-in at a time.
Hi thank you for your help.
The search box is the same, I’m getting this after a search for a not displayed component icon.
The Repair option gives me this message:
I’ll try the one-by-one method of loading GH. This wasn’t the case yesterday. Strange
Hi -
Could you run the Rhino SystemInfo command and copy-paste the result here?
Hi Wim,
I won’t be able to run the command because I reinstalled everything new in GH. Now it<s working again. My guess is that VisualArq was causing problems. I’ve updated to the latest build and Rhino is running smoothly.
Thanks again for your help
