Where can I find the mouse settings/configuration for Grasshopper? I would like to disable the pop-up menu that appears when I hold down the mouse wheel. Instead, I would like to be able to pan view when I hold down the mouse wheel, similar to how it is already used in Rhino.
That is non-standard behaviour though, but unfortunately Grasshopper doesn’t have ways to change the mouse button behaviour.
Is this still the case? it is 2 years later now…
I am able to customize Rhino wheel button use (to match Autodesk standards) but what about Grasshopper UI? Still nothing?
thank you
Regards
g
Still nothing. I doubt it’s going to happen for grasshopper 1.
