Can I customise my mouse button settings for Rhino.Inside.Revit? I have a different configuration for Rhino than for Revit and would like to also use this for Rhino in Revit. However, to do this, I need to reference a .exe file. Is it possible to make this work somehow?
Hi @Intuos,
There is this option that controls if RiR takes settings from Rhino standalone or have a different set of settings when running in Revit.
I did a couple of tests and opened/closed Revit to see if this option had any effect, but it didn’t. My mouse driver is not picking this up.
Okay, in that case, I would have to wait for the actual implementation of:
Shift + MMB = Rotate
MMB = Pan
As was requested by me here: Rhino viewport navigation request - #12 by kike
Thanks for the help anyways @kike!
Unfortunately, I still need to pan with RMB in Grasshopper, which is why I changed the settings on my mouse in the first place. It gets confusing quickly if all your software is configured for MMB pan and then Grasshopper doesn’t all of a sudden ![]()
