Grasshopper make 2D question
I’m a beginner using Make 2D.
I want to create a 2D shape using Make 2D, but I’m having trouble with the view settings. When I attach the shape to the model and set the view like this, the 2D shape gets cropped, but even if I resize it, it doesn’t seem to improve much. If anyone has any tips, I’d like to ask for a setup guide. Thank you.
In the photo, the ㄷ-shaped shape taken from the right side does not appear.
test.stp (26.4 KB)
test2.gh (17.9 KB) (fixed)
Hi 오민성 -
Please always list required plug-ins.
I removed the plug-in and modified the file.
Only basic components were used.
If you’re using Rhino 8, and it is not imperative to use grasshopper, use Clipping Drawings command in Rhino, its 10 times better and faster than the old make 2d
Hi 오민성 -
I’m not seeing that here.
[I have internalized your STEP file…]
오민성-test2-internalized-RH8.gh (17.4 KB)
Please run the Rhino SystemInfo command and copy-paste its output here.
