Hi ,
I have made one custom endpoint which calls the grasshopper definition and provides it a json input. I have hosted it on ec2 instance. when the first 2 or 3 requests come it works correctly and gives the results. when more requests come it starts to give internal server error 500.
To be more precise there is no parallel request processing is going on. all the requests stays in queue and they get process sequentially. I am attaching the below code that I have implemented for the custom endpoint. Initially I thought may cache issue is there due to which it starts breaking after certain requests hence I clear it with gH_ComponentServer.Clear(); but it does not work
private string ExecuteDefinitionSingleParameter(string definitionPath)
List<GrasshopperDataTree> inputParams = null;
List<GrasshopperDataTree> results = null;
GH_ComponentServer gH_ComponentServer = new GH_ComponentServer();
try
if (string.IsNullOrWhiteSpace(definitionPath))
throw new ArgumentNullException(nameof(definitionPath),
"Grasshopper definition path is missing or invalid.");
inputParams = BuildInputParamsSingleParameter();
results = GrasshopperCompute.EvaluateDefinition(definitionPath, inputParams).ToList();
if (results == null || results.Count == 0)
throw new InvalidOperationException("No results returned from Grasshopper definition.");
Log($"Definition executed successfully: {definitionPath}");
return "Definition executed successfully";
catch (Exception ex)
Log($"Error in ExecuteDefinition: {ex}");
return $"Error running analyzer: {ex.Message}";
finally
// CRITICAL: break references
results = null;
inputParams = null;
Rhino.RhinoDoc.ActiveDoc?.Objects.Clear();
GC.Collect();
GC.WaitForPendingFinalizers();
GC.Collect();
in some logs I find this
CG [13:48:46 WRN] As of “01/10/2026 08:18:45 +00:00”, the heartbeat has been running for “00:02:47.5370368” which is longer than “00:00:01”. This could be caused by thread pool starvation.
RC [13:49:39 INF] Max concurrent requests = 2
CG [13:49:41 WRN] As of “01/10/2026 08:19:41 +00:00”, the heartbeat has been running for “00:00:53.0065572” which is longer than “00:00:01”. This could be caused by thread pool starvation.
