Is this somehow possible? Because that’s basically my criterium for making them visible or hidden.
private void RunScript(bool active, int d)
if(!active) return;
_d = d;
foreach(var obj in GrasshopperDocument.ActiveObjects())
if(obj is IGH_Param)
HideLongWire((IGH_Param) obj);
else if(obj is IGH_Component)
var comp = (IGH_Component) obj;
foreach(var param in comp.Params)
HideLongWire(param);
// <Custom additional code>
int _d = 1000;
void HideLongWire(IGH_Param param)
var tPivot = param.Attributes.Pivot;
foreach(var s in param.Sources)
var sPivot = s.Attributes.Pivot;
var d = Math.Sqrt(Math.Pow((sPivot.X - tPivot.X), 2) + Math.Pow((sPivot.Y - tPivot.Y), 2));
if (d > _d)
param.WireDisplay = (GH_ParamWireDisplay) 0;
continue;
param.WireDisplay = (GH_ParamWireDisplay) 2;
return;
// </Custom additional code>
Wire.gh (7.0 KB)
thanks for both options. I like the compact solution @Mahdiyar posted.
There are 2 issues:
- it doesn’t work on relays
- all my telepathy components get affected. How do I cancel these from being selected?
found this one by selecting them out with (obj.Name != “Remote Receiver”)
if(!active) return;
_d = d;
if(obj.Name == "Remote Receiver") continue;
int _d = 1000;
if (d < _d)
continue;
return;
Wire.gh (10.1 KB)
