When simply adding “Print(x.ToString());” in the RunScript function, I get an error. Basically, the C# component won’t work whatever I put in the RunScript function. See this image for the error:
It appears to be trying to write the component script to the C:\Windows folder, which cannot succeed (no admin rights), then reads the assembly again. I guess it should actually try to write to a different folder.
Anyone familiar with this issue? When working on another PC, I don’t get the error. So I think it must be some setting (maybe even in the installed .NET framework?) that should be changed? If anyone can shed some light on what’s going on, thanks!
