Hi all,
i tried to compile a c# script in visiual studio to get a grasshopper component. The script works as a c# script component but not as a compiled component but it throughs also no error and compile successful.
The problem is that the compiled component does nothing and the question is how can i debug or find the error so that the component do what it should do ?.
using System;
using System.Collections;
using System.Collections.Generic;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using System.IO;
using NPOI.XSSF.UserModel;
using NPOI.XSSF.Model;
using NPOI.HSSF.Model;
using NPOI.HSSF.UserModel;
using NPOI.SS.UserModel;
using ICSharpCode.SharpZipLib;
using NPOI.SS.Util;
/// <summary>
/// This class will be instantiated on demand by the Script component.
/// </summary>
public class Script_Instance : GH_ScriptInstance
#region Utility functions
/// <summary>Print a String to the [Out] Parameter of the Script component.</summary>
/// <param name="text">String to print.</param>
private void Print(string text) { /* Implementation hidden. */ }
/// <summary>Print a formatted String to the [Out] Parameter of the Script component.</summary>
/// <param name="format">String format.</param>
/// <param name="args">Formatting parameters.</param>
private void Print(string format, params object[] args) { /* Implementation hidden. */ }
/// <summary>Print useful information about an object instance to the [Out] Parameter of the Script component. </summary>
/// <param name="obj">Object instance to parse.</param>
private void Reflect(object obj) { /* Implementation hidden. */ }
/// <summary>Print the signatures of all the overloads of a specific method to the [Out] Parameter of the Script component. </summary>
private void Reflect(object obj, string method_name) { /* Implementation hidden. */ }
#endregion
#region Members
/// <summary>Gets the current Rhino document.</summary>
private readonly RhinoDoc RhinoDocument;
/// <summary>Gets the Grasshopper document that owns this script.</summary>
private readonly GH_Document GrasshopperDocument;
/// <summary>Gets the Grasshopper script component that owns this script.</summary>
private readonly IGH_Component Component;
/// <summary>
/// Gets the current iteration count. The first call to RunScript() is associated with Iteration==0.
/// Any subsequent call within the same solution will increment the Iteration count.
/// </summary>
private readonly int Iteration;
#endregion
/// <summary>
/// This procedure contains the user code. Input parameters are provided as regular arguments,
/// Output parameters as ref arguments. You don't have to assign output parameters,
/// they will have a default value.
/// </summary>
private void RunScript(bool Execute, string PathOpen, string PathSave, string Sheet, string RowColStart, DataTree<object> Table)
if (Execute)
HSSFWorkbook wb;
using (FileStream fs = new FileStream(PathOpen, FileMode.Open, FileAccess.Read))
wb = new HSSFWorkbook(fs);
ISheet sheet = wb.GetSheet(Sheet);
CellReference c = new CellReference(RowColStart);
int columnC = (int) Table.Branches.Count;
int rowC = (int) Table.Branch(0).Count;
Print(c.Row.ToString());
for (int i = c.Row ; i <= c.Row + rowC - 1 ; i++)
IRow row = sheet.GetRow(i);
if (row == null)
IRow rowCr = sheet.CreateRow(i);
for (int r = c.Col ; r <= c.Col + columnC - 1 ; r++)
var x = Table.Branch(r - c.Col)[i - c.Row];
string B = Convert.ToString(x);
if (string.IsNullOrEmpty(B))
rowCr.CreateCell(r).SetCellType(CellType.Blank);
else
double dob;
if (double.TryParse(B, out dob))
rowCr.CreateCell(r).SetCellValue(dob);
else
rowCr.CreateCell(r).SetCellValue(0);
else
ICell cell = row.GetCell(r, MissingCellPolicy.RETURN_NULL_AND_BLANK);
if (cell == null)
row.CreateCell(r).SetCellValue(0);
else
double dob;
row.CreateCell(r).SetCellValue(dob);
else
else
cell.SetCellValue(0);
else
double dob;
cell.SetCellValue(dob);
else
cell.SetCellValue(B);
wb.ForceFormulaRecalculation = true;
using (FileStream fs = new FileStream(PathSave, FileMode.Create, FileAccess.Write))
wb.Write(fs);
wb.Close();
// <Custom additional code>
// </Custom additional code>
The code in visual studio.
using System;
using System.IO;
using NPOI.SS.Util;
// In order to load the result of this wizard, you will also need to
// add the output bin/ folder of this project to the list of loaded
// folder in Grasshopper.
// You can use the _GrasshopperDeveloperSettings Rhino command for that.
namespace XLS_Writer
public class XLSWriterComponent : GH_Component
/// <summary>
/// Each implementation of GH_Component must provide a public
/// constructor without any arguments.
/// Category represents the Tab in which the component will appear,
/// Subcategory the panel. If you use non-existing tab or panel names,
/// new tabs/panels will automatically be created.
/// </summary>
public XLSWriterComponent()
: base("XLS_Writer", "Nickname",
"Description",
"Category", "Subcategory")
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddBooleanParameter("Execute", "Execute", "run the component", GH_ParamAccess.item, false);
pManager.AddTextParameter("PathOpen", "PathOpen", "path for existing xls file", GH_ParamAccess.item, "None");
pManager.AddTextParameter("PathSave", "PathSave", "path for modified xls file", GH_ParamAccess.item, "None");
pManager.AddTextParameter("Sheet", "Sheet", "xls sheet name", GH_ParamAccess.item, "None");
pManager.AddTextParameter("RowColStart", "RowColStart", "", GH_ParamAccess.item, "None");
pManager.AddGenericParameter("Table", "Table", "data table", GH_ParamAccess.tree);
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object can be used to retrieve data from input parameters and
/// to store data in output parameters.</param>
protected override void SolveInstance(IGH_DataAccess DA)
bool execute = false;
string PathOpen = "None";
string PathSave = "None";
string Sheet = "None";
string RowColStart = "None";
string Table = "None";
if (!DA.GetData(0, ref execute)) return;
if (!DA.GetData(1, ref PathOpen)) return;
if (!DA.GetData(2, ref PathSave)) return;
if (!DA.GetData(3, ref Sheet)) return;
if (!DA.GetData(4, ref RowColStart)) return;
if (!DA.GetData(4, ref Table)) return;
private void XLSWrite(bool execute, string PathOpen, string PathSave,string Sheet, string RowColStart, Grasshopper.DataTree<object> Table)
if (execute)
HSSFWorkbook wb;
int columnC = (int)Table.Branches.Count;
int rowC = (int)Table.Branch(0).Count;
//Print(c.Row.ToString());
for (int i = c.Row; i <= c.Row + rowC - 1; i++)
if (row == null)
for (int r = c.Col; r <= c.Col + columnC - 1; r++)
else
if (double.TryParse(B, out double dob))
else
else
if (cell == null)
else
else
else
else
else
wb.Write(fs);
wb.Close();
/// <summary>
/// Provides an Icon for every component that will be visible in the User Interface.
/// Icons need to be 24x24 pixels.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
// You can add image files to your project resources and access them like this:
//return Resources.IconForThisComponent;
return null;
/// <summary>
/// Each component must have a unique Guid to identify it.
/// It is vital this Guid doesn't change otherwise old ghx files
/// that use the old ID will partially fail during loading.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("80160204-7edf-44eb-afbe-053fe0c7b5ea"); }
Any tips what the problem could be is welcome.
