Hi there, is anyone able to help me. I am trying to update an old c# component that is expired in grasshopper. I created a new one and have copied the exact code but am still receiving an error saying ¨ERROR CS0246¨ applying to the following line of code:
static string Format(Color c)
return (new System.Text.StringBuilder(“A”)).Append(c.A.ToString()).Append(“R”).Append(c.R.ToString()).Append(“G”)
.Append(c.G.ToString()).Append(“B”).Append(c.B.ToString()).ToString();
i dont understand though as it is the exact same as the expired component.
Note: if your goal is just to Insert/Bake geometry into the Rhino document, with custom attributes … well … I have far more “modern” things. Notify in case that you need one (but you should EXPLICITLY describe what you are after).
PS: What is this chaos? Is a Graph due to some Prox Method? You want to Cluster the Lines according to some Length Interval divisions (user defined) and then assign Colors? (if yes that’s very easy - just a single LINQ GroupBy line - and real-time fast).
PS: In real life for that sort of Clustering we use only 2 “basic” Colors: say Green for the smallest, Red for the biggest and a linear interpolation between these 2.
