I am running grasshopper on Rhino 7 and get this error when trying to create an object. I have the human, humanUI, and Rhino.inside.Revit plugins. Unfortunately, I cannot confirm if this error occured before the plug-ins were installed as I did not try creating objects before they were installed. This error occurs both when using grasshopper from Rhino and when opening through Revit.
Attached below is the standard grasshopper in Rhino error breakpoint:
Hi Dale, I believe this is not purely a Rhino.inside issue as it occurs with base grasshopper as well. When using rhino.inside, this issue occurs both with a blank template and with predefined models. In other words, I cannot create any objects in any instances of grasshopper via any method of opening grasshopper
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-3-2022 (M-D-Y).
Primary OpenGL: NVIDIA RTX A2000 8GB Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.79
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-9-2023
Driver Version: 31.0.15.2879
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
Hey Dale, sorry for the late update but unfortunately, updating my Rhino7 to SR29 did not fix the issue. Do you have any other suggestions as to why I could be getting this error?
