Grasshopper break point error?
need help :wink:
Hi Paul -
Are you using any non-default Grasshopper plug-ins?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05001, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Commerciale, build 2022-09-12
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) HD Graphics 530 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
- Windows Main Display attached to adapter port #1
Primary OpenGL: NVIDIA GeForce GTX 980M (NVidia) Memory: 4GB, Driver date: 6-21-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 451.48
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-21-2020
Driver Version: 27.21.14.5148
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\CreateQuadMesh (5bf6c0f3-3657-4ad5-834a-bbbb52706a40)\6.0.6950.16446\CreateQuadMesh.rhp “CreateQuadMesh” 6.0.6950.16446
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\grasshoppercmd\6.0.0+0\GrasshopperCMD.rhp “GrasshopperCMD” 6.0.0.0
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PetersTools\3.1.3\PetersTools.rhp “PetersTools” 3.1.7989.39042
C:\Program Files\SimLab\Plugins\SimLab Rhino 6 Integration\SimLabComposerIntegration.rhp “SimLab Composer Integration”
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\lcRhino\2.5.799-pre\lcRhino.rhp “lcRhino” 2.5.799.0
C:\Program Files\Geometry Gym\Rhino7\BullAnt.rhp “bullant” 1.5.6.0
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino WIP\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.22.22255.5001
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.22.22255.5001
C:\Users\pm\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
A quick thing we can check as well is to move the contents of your grasshopper plugins folder/components to a temp folder (desktop for instance) and restart Rhino- Grasshopper
%AppData%\Grasshopper\Libraries
%AppData%\Grasshopper\UserObjects
Hi Wim, Hi Japhy,
thanks for your help!!
it’s doesn’t work… i’ve got a new message from grasshopper breakpoint.
Best regards
Try removing the Stripper plugin via the packageManager.
It’s working good!! many thanks!!
now i have this massage when i load a snippet w
massage after load anippet from Brick Box plugin
it Brick Box plug in…
Seems like you have something bigger going on, lets see if anyone else can chime in with a probable root cause.
The GH file you were trying to load might contain invalid IDs. Does the breakpoint thing happen in specific GH files?
Hi Pm!
Was wondering if you were able to see any solutions to this by any chance? I am running through the same problem w Brickbox right now.
