could I know what causes this creen each time i open Gh and it apears 3 times
Hi @huss191998,
What version and service release of Rhino are you using? (If you don’t know, run Rhino’s SystemInfo command). Do you see this when you just open GH? If so, what GH plug-ins do you have installed?
– Dale
Thanks for reply Dale
it happens every time 'm trying to open GH in Rhino 7 and 6 also
it appears when ghpython is loading and I don’t know why ?
my system info
Rhino 7 SR4 2021-3-19 (Rhino 7, 7.4.21078.01001, Git hash:master @ a432d22ab7f0f7b53d157d578278070c8bf6eff4)
License type: Evaluation, build 2021-03-19
License details: Stand-Alone
Expires on: 2021-04-26
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [60% battery remaining]
Primary display: Intel(R) HD Graphics 520 (Intel) Memory: 1GB, Driver date: 2-28-2018 (M-D-Y).
Primary OpenGL: AMD Radeon ™ R7 M360 (AMD) Memory: 4GB, Driver date: 2-17-2021 (M-D-Y). OpenGL Ver: 4.6.14760 Compatibility Profile Context 21.2.3 27.20.14535.3005
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 2-17-2021
Driver Version: 27.20.14535.3005
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Geometry Gym\Rhino7\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.1.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Geometry Gym\Rhino7\BullAnt.rhp “bullant” 1.5.6.0
C:\Program Files\Geometry Gym\RhinoWIP\ggKaramba.rhp “ggKaramba” 0.2.1.0
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Users\20101\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.20335.757
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot10RhinoPlugin (ccedd9da-83b9-429a-aec5-8ec90b85fe67)\1.0.0.0\KeyShot10RhinoPlugin\Rhino 5.0\KeyShot10RhinoPlugin.rhp “KeyShot10RhinoPlugin” 1.0.0.0
D:\Windows.old\Users\huss1\Desktop\softwares\Architecture soft\Mesh2Surface 6.09 Premium\m2s_for_Rhino6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\AMDDenoiser\0.4.1\AMDDenoiser.Windows.rhp “AMDDenoiser.Windows” 0.4.1.0
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\RhinoFileVersion\7.0.7703\RhinoFileVersion.rhp “Rhino 3DM File Version” 7.0.7703.19539
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21078.1001
C:\Users\20101\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
@dale any news?
Hi @huss191998,
1.) Launch Rhino and run the PlugInManager command.
2.) From PlugInManager disable all of the plug-ins that do not ship with Rhino.
3.) Close and re-open Rhino
4.) Launch Grasshopper.
5.) If Grasshopper loads without errors, run the PlugInManager and enable one of the plug-in, that do not ship with Rhino, that you disabled in Step 2.
6.) Jump to Step 3 and repeat.
Do this until you find the plug-in that causes the error.
– Dale
it appears at this stage
