Graphic quality Rhino7 vs Rhino8
I just bought Rhino8 and I notice a drop in quality between the two versions…
Mainly, the antialiasing which seems not to work properly.
I set everything to the maximum, but it doesn’t change anything…
All drivers are up to date.
Just a question, currently, isn’t there anything better than 8x antialiasing?
Rhino 7
Rhino 8 same folder, same view…
Capture antialiasing R8
Capture réglages R8
Hi
This issue has been discussed here.
Thanks.
hi @gaetan apart from the logged issue in the thread linked, I recommend tuning your wire display scale with _TestWireThicknessScale. On my system I’m getting good results with 0.65 and 1.3
(I tried posting an image, but the resulting image here doesn’t show the quality well)
It’s dependent on your display scaling. At what display scale are you running your screen?
