Gradient pattern using non-uniform hexagons
Hi, grasshopper newbie question.
I have been playing around with 2D Hexagon and Polygon Patterns.
Is it possible to create a grid of 2D hexagons with each scaling via non uniform vertices? My thinking is that I could then control these via a series of attractor points. See attached image of the kind of thing I’m trying to create parametrically.
Thanks advance for the help!
Conor
Maybe something like this?
or these two
You can also check out Daniel Piker’s Mobius Transformation component in Kangaroo.
Mobius Hexgrid.gh (8.0 KB)
Kangaroo Springs?
KANGAROO_MORPH Morph_Hex_Grid.gh (20.0 KB)
Not quite like the original image but fun to play with.
How about updating to Kangaroo 2.0, which was released 4+ years ago? Works great in R5:
My mistake, I thought I was using K2.
K1 still works great
Also, I’ve forgotten how to do springs from lines in K2
Thanks for the great suggestions guys.
Set me off in the right direction.
Cheers
Conor
So have I, could anyone weigh in on updating this to K2?
Trying to create a similar effect as this mushroom, the definition @martynjhogg posted is close but the geometry in K2 would be easier to control.
EDIT: Sorry for the necro post, this seemed more relevant than starting a new thread.
A different way to approach this could be as a mapping challenge -
So generate an isotropic hexagonal pattern, then make a pair of surfaces and adjust the isocurve spacing to the nonlinear one you want
sporph_pattern.gh (14.8 KB)
Thank you, that is very helpful. Is it possible to change the hierarchal direction on the mapping method? On the mushroom the cells are large in the center and fan out to small. That sort of focal point is what I am after, thought maybe a variation of the Springs would work.
I was trying a Project method but still wrapping my head around the topology needed on both ends.
Regarding the Kangaroo springs, what is the best way to recover/reform the hexagons into closed polylines after Kangaroo deformation? After you’ve removed the duplicate lines that originally joined them? Joint curve has understandably chaotic results.
From memory… isn’t there a Mesh output from the Kangaroo solver? If so then you can just get the FaceBoundary from the mesh.
Ah, bad memory… it was an old K1 definition. Might be possible to do something similar with K2 and a mesh…
Yes - you can keep polylines as polylines in the output by passing them to the solver via a ‘Show’ component, and getting the corresponding branch of the output.
Here a simple example
polylinesout.gh (10.2 KB)
You can also use this to pass through other geometry such as meshes, point collections etc
Starting point in K2… you can play about with the forces and strengths but it tends to crease and distort. You might be able to tweak it to get closer to your image target above?
Morph_Hex_Grid_K2.gh (19.9 KB)
missing
Here I thought Show was just something people attached to goals for fun. Thank you, that makes sense to me now.
You can just replace it with graph mapper
A little more to it than that, eh?
  • ReMap values before and after Graph Mapper
  • Which graph type and what shape?
  • I had to reduce the amplitude multiplier quite a bit.
Morph_Hex_Grid_K2_2022Oct26a.gh (17.4 KB)
you’re a capable grasshopperer, I knew you could do it!
This mushroom is very cool! I notice that the edges are largely hexagons but, their sides aren’t straight. What would be a good way to get this kind of polygon-but-the-sides-are-wobbly-or-curvy effect?
