It’s excellent to finally be able to bake gradient hatches with grasshopper!
however I’ve found that some will not print to PDF with the Rhino PDF printer.
I notice the gradient hatch selection shows just its two outlines, but not the “full” surface, like it does with the non-gradient hatches. But I guess that doesn’t mean anything.
Edit: I notice that the behaviour is as expected when choosing “raster output”. This is not possible in my case however.
Sorry for the late reply. Can you share the file we can use to reproduce this here? Even just the section of file would be fine. If we can figure out the steps to reproduce it, we can likely fix it.
I’m seeing things amiss in your file. Is this a file that was created earlier and now opened in 8.22? If so, can you reproduce this from scratch? I’m not able to do so on my systems here.
