Grab mesh material from the "Earth" and export to revit
Halo ,
yesterday i help colleagus grab the terrain and mesh from the "earth ",like this below
and it is very succesful to export to revit via rhino inside revit ,
unfortunately, i find it cannot export the mesh material i.e. the map picture to revit ,
may i know how to export the map picture material to revit ?
finally i export to NWD with fbx, format ,but the picture is not clear
many thanks
Brad
test.7z (6.3 MB)
Hi @user2450,
For now, I think there is no way to transfer this material from Lands to Revit using Rhino.inside.Revit… I will let you know when this is possible.
As for the problem after exporting to fbx… Once you download the mesh from the Earth importer, what you have is Rhino geometry with a material, so I think people in McNeel will know better how to solve this: Rhino - Rhino Support
Fortunately , landsdesign provide a photo material ,i put it on revit material directly and uv is correct.thanks god
finally i success to place image material on terrain by hand or by node,please check my vdo for process
