Hi, I recently purchased a large 3D model of my local area with aerial imagery as the texture. The file consisted of numerous folders and within each folder were loads of GLB format files. I assume each of these GLB files is a small part of the larger model. I tried importing one of the files into Rhino but nothing happened. I then tried importing into Blender and got this response: Extension KHR_texture_basisu is not available on this addon version. I assume this is also the reason why Rhino is not recognising the file but if anyone could confirm that would be very helpful. I am trying to get the company to resend the file in a different format but they are being very uncooperative so trying to find an alternative solution. I have attached the file I am trying to import.
31123013302021.glb (187.3 KB)
I was able to view the file by uploading here
Validation report
- Format: glTF 2.0
- Generator: ClientFormatEncoding
- Stats:
- 1 draw calls
- 0 animations
- 1 materials
- 21492 vertices
- 9765 triangles
- Extensions:
- KHR_texture_basisu
- KHR_draco_mesh_compressionNOTE: Extensions above are present in the model, but may or may not be recognized by this viewer. Any “UNSUPPORTED_EXTENSION” warnings below refer only to extensions that could not be scanned by the validation suite, and may still have rendered correctly. See: three-gltf-viewer#122.
Report generated byKhronosGroup/glTF-Validator 2.0.0-dev.3.9.
| Warning | Message | Pointer |
VALUE_NOT_IN_LIST |
Invalid value ‘image/ktx2’. Valid values are (‘image/jpeg’, ‘image/png’). | /images/0/mimeType |
IMAGE_UNRECOGNIZED_FORMAT |
Image format not recognized. | /images/0 |
| Info | Message | Pointer |
UNSUPPORTED_EXTENSION |
Cannot validate an extension as it is not supported by the validator: ‘KHR_texture_basisu’. | /extensionsUsed/0 |
Cannot validate an extension as it is not supported by the validator: ‘KHR_draco_mesh_compression’. | /extensionsUsed/1 |
UNUSED_OBJECT |
This object may be unused. | /bufferViews/1 |
UNUSED_OBJECT |
This object may be unused. | /images/0 |
Hi Louis -
I’ve put this on the list for a closer look.
→ RH-83710 File IO: Error Importing GLB
Yes, that is why it’s not importing into Rhino. The base glTF specification only allows for images to be encoded as PNG or JPEG. When using the KHR_texture_basisu extension images can also be encoded as KTX2 compressed images. KTX2 is a format I’ve never heard of until I looked into this bug. As far as I can tell the format is specially designed to be compressed on and streamed directly to the graphics card. I don’t think we’ll support reading those images anytime soon. We should still be able to handle this and read in what we can.
I imagine for your use case the textures are quite important. I would ask whoever you bought the 3D models from if they have a different version with the images for the textures encoded differently.
Thanks Joshua,
Yes they have gotten back to me and agreed this is an issue that needs to be fixed on their end. Thanks for looking into it.
RH-83710 is fixed in Rhino 8 Service Release 12
Reviving this topic, since I have a fairly similar issue.
I’m struggling to import binary GLTF map tile downloaded from a service following the OGC (Cesium) 3D Tiles spec.
Here an example tile, as it can be downloaded trough the service.
120.glb (7.2 KB)
On import, Rhino command line shows only one error message:
Error importing file "C:\Users\Ondrej Vesely\Downloads\71.glb".
Here is the validation report provided by glTF Viewer.
Validation report
- Format: glTF 2.0
- Generator: Geoflow
- Stats:
- 1 draw calls
- 0 animations
- 1 materials
- 594 vertices
- 320 triangles
- Extensions:
- EXT_mesh_features
- EXT_meshopt_compression
- KHR_mesh_quantization
- EXT_structural_metadataNOTE: Extensions above are present in the model, but may or may not be recognized by this viewer. Any “UNSUPPORTED_EXTENSION” warnings below refer only to extensions that could not be scanned by the validation suite, and may still have rendered correctly. See: three-gltf-viewer#122.
Info Message Pointer UNSUPPORTED_EXTENSIONCannot validate an extension as it is not supported by the validator: ‘EXT_mesh_features’. /extensionsUsed/0UNSUPPORTED_EXTENSIONCannot validate an extension as it is not supported by the validator: ‘EXT_meshopt_compression’. /extensionsUsed/1UNSUPPORTED_EXTENSIONCannot validate an extension as it is not supported by the validator: ‘EXT_structural_metadata’. /extensionsUsed/3UNUSED_OBJECTThis object may be unused. /bufferViews/2UNUSED_OBJECTThis object may be unused. /bufferViews/3UNUSED_OBJECTThis object may be unused. /bufferViews/4UNUSED_OBJECTThis object may be unused. /bufferViews/5
I am seeing the same issue as Ondrej with a file (which I sadly cannot share). Here is the validtaion report
* **Format:** glTF 2.0
* **Generator:** gltfpack 0.21
* **Stats:**
* 111 draw calls
* 36 animations
* 43 materials
* 72027 vertices
* 52911 triangles
* **Extensions:**
* EXT_meshopt_compression
* KHR_materials_ior
* KHR_materials_specular
* KHR_texture_basisu
In both yours and @chris_dardis case our glTF importer currently does not support the EXT_meshopt_compression extension. Until I add support for it I think you’ll need to see if they have versions of the file that are uncompressed or compressed with draco.
