GISMO: TerrainGenerator Issue
Hi @djordje
I am just giving Gismo a whirl for generating topographic terrain data. When I run the analyse_terrain.gh example everything seems to work as expected:
However, if I change the latitude/longitude to say 64.00,00.00 , I get these errors:
Any ideas of what might be causing this? Looks like it might be a number of things.
(Also, if it is more appropriate to post Gismo issues elsewhere, I’d be happy to do so)
Best,
Anders
Using the second source_ option appears to work:
Still though, it would be great to know why the first method fails (just educating myself here :slight_smile: )
/A
When no “_source” is supplied the default SRTMGL1 source only gets terrain from -55 to 59 latitude.
Maybe the error you get is because you were giving a latitude of 64.
That was exactly it, I simply didn’t manage to read the input params documentation close enough :man_facepalming:
Hi @AndersDeleuran. I am glad the issue was solved by @jaco. Thank you Jaco!
I definitely admit that the component should simply stop working if SRTMGL1 has been chosen for the “_source” input, if location’s latitude exceeds supported mentioned latitude.
Anders, if you have any other issues, you can also open a topic on Gismo group.
In the spirit of sinking ships/splintering userbases, perhaps adding a Gismo Grasshopper subcategory might also be appropriate :flight_arrival:
