GHPython, triangulate mesh
Hello!
I wrote a GHPython script that takes a mesh as input and creates a mesh shell from it. It only makes sense with triangulated meshes, so, at first, I want to check if the input mesh has quad faces and triangulate it if so.
There’s a code example in the RhinoScriptSyntax docs:
obj = rs.GetObject(“Select mesh”, rs.filter.mesh )
if rs.MeshQuadCount(obj)>0:
rs.MeshQuadsToTriangles(obj)
This works when the Python component’s mesh input type hint is set to “ghdoc”.
However, I need the type hint set to “mesh”, because later in the code I use RhinoCommon access to mesh.TopologyVertices and mesh.TopologyEdges.
There does not seem to be a “triangulate” function in Rhino.Geometry.Mesh.
So, is there a way to get the mesh data from a Guid object?
Thanks!
Best regards
Eugen
mesh = rs.coercemesh(mesh_guid)
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Collections_MeshFaceList_ConvertQuadsToTriangles.htm
The rhinoscriptsyntax code is open source on Github, so you can see how everything is done under the hood: rhinoscriptsyntax/Scripts/rhinoscript/mesh.py at 15a1d3964703dffe798118f9b5583c93368e3634 · mcneel/rhinoscriptsyntax · GitHub
Thank you, sir! So, both ways are possible.
Best regards
Eugen
