I have tried to solve this and is unable to. Anyone with understanding of GhPython, node to code and lofting?
Thank you.
GhPython Node to Code - Loft options.gh (5.3 KB)
Thank you.
@Alain do you think you could have a look?
The problem is that in your script the function:
loft = ghcomp.LoftOptions(True,False,0,0,0)
returns a string instead of the expected type LoftOptions. I’m investigation the problem but you could consider using the rhinoscriptsyntax AddLoftSurface function instead.
Hope this helps
Thank you, rhinoscriptsyntax AddLoftSurface is a suitable alternative.
RH-48617 is fixed in Rhino 7 Service Release 9
