GH_Python component Loft option
The same issue was reported before: GhPython Node to Code - Loft: input 2 options. error: Data conversion failed from Text to Loft Options. A workaround with AddLoftSurface was reported as working. Does that work for you too?
This is tracked as RH-48617 Some component parameters are converted to strings instead of objects.
