Hi David,
This is a GH2 bug report generated by Claude. Over here we are testing GH1 to GH2 conversions of scripts I made in the past and Claude does a very useful job for this.
@stevebaer, @brian, @CallumSykes, @Gijs , is it an idea that McNeel creates a Discourse place where we can upload posts generated by an AI agent? And that your AI agent is able to examine them?
This is the bug:
The Curvature Display component faults on the attached ship hull surface. On a sphere and on a plane it works fine.
Curvature Display fault - hull surface.ghz (19.1 KB)
Hull surface (Rhino 8 format).3dm (15.5 KB)
To reproduce
- Open the attached
.ghz(the surface is internalised in a Surface parameter). - The surface is connected to Curvature Display > Shape, all other inputs are default.
Result: the component turns red and gives no mesh.
Expected: a mesh coloured by curvature.
Error
NullReferenceException: Object reference not set to an instance of an object.
at DisplayComponents.Analysis.CurvatureShader.HarvestCurvature(Surface surface, Mesh mesh, CurvatureKind kind, Double[]& k)
at DisplayComponents.Analysis.CurvatureShader.ShapeToMesh(Object shape, Double absoluteTolerance, Double angularTolerance, CurvatureKind kind, Double[]& k)
at DisplayComponents.Analysis.CurvatureShader.Process(IDataAccess access)
at Grasshopper2.Components.Component.ComputeInternal(Solution solution, CallStack stack)
at Grasshopper2.Doc.ActiveObject.ComputeAndAssign(ObjectSolutionState state, Solution solution, CallStack stack)
Possible cause
The surface is a single untrimmed NURBS surface, degree 3 x 3, 10 x 9 control points, model units mm (about 100 m long). At one corner (u = max, v = min, point 92399.1, 0, 0) the first derivative in the U direction is almost zero (length about 2e-5). At exactly that corner RhinoCommon Surface.CurvatureAt(u, v) returns null; everywhere else it returns a value. My guess is that HarvestCurvature does not check for a null result.
This kind of corner is normal in ship hull surfaces. Grasshopper 1 colours the same surface by Gaussian curvature without problems.
System
Rhino 9.1.26300.6001 (build date 27 Oct 2026), Grasshopper 2 from the same build, Windows 11 (10.0.26200).
_SystemInfo:
Rhino 9 SR1 2026-10-27 (Rhino 9, 9.1.26300.06001, Git hash:master @ d4917e26aa263f8c01aa5cc598b4c2d06e13e913)
License type: Not For Resale Lab, build 2026-10-27
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 10.0.15
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA RTX A2000 (NVidia) Memory: 6GB, Driver date: 7-10-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 4 adapter port(s)
Secondary graphics devices.
Intel(R) Graphics (Intel) Memory: 18GB, Driver date: 8-24-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
- There are no monitors attached to this device!
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.1.26300.6001
C:\Program Files\Rhino 9\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9\Plug-ins\SectionTools.rhp “SectionTools”
Thanks,
Gerard
