I’ve a gh file that generate the offset on some given curves, but the result sometimes is wrong (as shown on the image); the correct offset should be the green line.
Saw all of this and thought of this. Offset Thought.gh (18.9 KB)
Simply uses pipes to offset the curve.
Some one will have to figure out how to sort some of the curves though.
The first pic shows at least one of the problems with it.
Also… It only works on closed curves.
