Gh - Move along direction does not work properly
Essentially I want to make an offset of my external curves/points along specific direction given by various radial curves from which I take the movement vector but the points move in a different way than the vector display arrow.
Hi, I’m probably missing something.
Can’t share the source file.
EDIT: stupid mistake, points and lines were not sorted the same way -.-
2024-07-16-13-29-50
Most likely the data structure of the geometry and vectors does not match.
The *.gif is useless, you’d have to post a file with the relevant parts of your definition…
You can also check the data structure yourself. Both geometry and vector input should have at least the same number of branches.
