Hi gang, Im looking to adjust the offset of my triangle more dynamically.
At the moment, i managed, with one parameter adjustment, move all points in an inset motion.
However, i am having trouble for the lowest point to move in an axis that is parallel to my geometry.
Also, i can understand this is not the most intuitive way of doing this. Happy for any suggestions.
Thanks gang.
Liam
Step 1, Offset from main geometry
Step 2, Further offset
however, not following desired axis / parallel to its former geometry
240219_Triangle Column.gh (18.4 KB)
Model test.3dm (7.8 MB)
I am also looking to sweep the circle geometry around the 1st and 2nd line to create a loop but am struggling to do so. Any tips would be appreciated. thanks gang
Why Why use a plugin when there is a standard GH component? More importantly, why use Shift Paths at all when the data tree you are shifting looks like this
When code starts this way, nothing good will come of it… and indeed, on further examination, nothing about your code makes sense.
As far as I remember, people were seeking a ‘safer’ ShiftPath, and some packages provided it.
I know about the flaws in the standard component:
This is INSANELY annoying! This is a flaw that should be fixed, and I don’t care who’s code the fix might break. It’s a mistake to work as it does.
I just created a “Smart PShift” cluster to handle this. pShift works for me, though perhaps could be done better?
It is demonstrated in the following code, internal to another cluster crvXYZ that sorts curves by X, Y or Z of their midpoints.
[PShift_smart_2020Apr28a2]
[PShift_smart_2020Apr28a]
PShift_smart_2020Apr28a.gh (42.2 KB)
But in this case, there appears to be no reason to use it at all.
This GH code is terrible. I would post a better way but don’t even know what @Liam_yongging is trying to do?
