I suddenly have an error appearing when I start Grasshopper see image:
I’ve spent over hours trying to find out what it is. I don’t use Karamba and while back I have uninstalled it.
Any clue as to what causing this?
It seems that you haven’t completely uninstalled karamba. Have a look on your components folder (File-> Special Folders-> Components Folder).
Thanks but, I’ve already checked both library folders (appdata/roaming/Grasshopper and the Program Files\Rhino 6\Plug-ins\Grasshopper\Components folder) and also the rest of the c: drive. That’s why it’s taken me hours. It’s mysterious as it suddenly appeared. Clicking the OK and GH works fine, but I’ll probably try reinstalling it and see if the error goes away, as it’s already annoying .
I figured out the problem it’s to do with Digitalis component: (the component requires Karamba installed)
