adbizau
(Adbizau)
May 28, 2024, 7:53pm
1
Can anyone check and please tell me why this is happening?
This is happening in a new file in Rhino8, with this definition:
Weird behaviour.gh (4.5 KB)
In the image posted, I tried replacing the are component but I got the same result.
I tried with the evaluate surface component and I got the same thing:
If I open this in Rh7, it works normally.
Am I missing something plainly obvious?
Thank you in advance!
wim
(Wim Dekeyser)
May 29, 2024, 6:21am
2
Hi Adrian -
Not that I can see, no. I’ve put this on the list of a developer to take a closer look → RH-82220 Grasshopper: Extrude is offset from base curve
For now, you can explode the curve before extruding it, and then, if necessary, join the resulting extrusions.
If the curve is replaced with a rectangle, it also works normally in Rhino 8
kike
(Kike Garcia)
June 3, 2024, 8:03pm
4
It will be fixed on next v8.8 RC
brian
(Brian Gillespie)
June 6, 2024, 4:17pm
5
dan
(Dan)
June 11, 2024, 9:14pm
6
