Gh, brep into go
Ime finding it difficult to transform a brep I’ve created into a geometry where I can then bake the file and print it. could someone please let me know what I am miss?
thank you
TABLE.gh (22.8 KB)
If you use an XZ Plane for your offset curve instead of the XY Plane you were using your file produces closed breps.
I would use Loft instead of Ruled Surface to produce your base surfaces.
Don’t know how you plan to print these thin frames, but the file produces closed breps.
TABLE_221110a.gh (18.7 KB)
-Kevin
Thank you, Kevin. Is there a way to take the brep and convert it into a geometry?
I am not sure what you are asking here. A closed brep can be baked into Rhino as a polysurface (right-click on the Extrude component and select Bake…).
-Kevin
