GGym Layered wall export
Hello I am trying to create an ifc wall with has multiple material layers (i.e. insulation and concrete) and export the geometry . When i attempt to do it using standard wall case, i can pass the material layers but cannot export/visualize them as separate entities. To do this i used as reference the example file 11-IFC-Feature -wall build up.ghx , where you have the separate materials defined (but also there is no geometry representation)
I tried to create geometric representations (i.e. extrusion) for each material layer and combine the representations into an wall element but when I do this I get no geometry in the export . Attached a couple of screenshots, two ifc exports and the script.
Any feedback would be welcome
Rhino-ghx screenshot
test_Wall_export_separateMAterials.zip (14.0 KB)
(upload://16LoqWdV0xbosQQi2akmELVCryF.zip) (12.6 KB)
createLAyeredWall_test01.gh (23.5 KB)
screenshot from when importing the wall element with separate material layers
