Getting Rhinoceros Graphics Driver Crashed popup when I start up Rhino, recently started happening when using remote desktop. It seems to be causing Rhino to crash quite often when orbiting around the model.
If you follow those instructions, what do you learn?
Nothing seems to be obviously wrong, or any recommendations for a better configuration, when I go into the System Information and everything says status “OK”. Is there anything I should be looking for specifically?
Please post the SystemInfo so I can have a look.
Thanks
Apparently you are using different email addresses for the Forum and for your license Registration and Validation.
That can be a confusing mess to manage two separate identities.
It’s because I’m using a remote machine, the laptop I’m using is logged in on an old account I had.
Okay, that makes sense with the accounts confusion.
“SystemInfo” is a command in Rhino V6 and V7.
Ahh apologies
Rhino 6 SR32 2020-12-5 (Rhino 6, 6.32.20340.21001, Git hash:master @ f0da95af49009959d0100568acb11aea288bcea0)
License type: Commercial, build 2020-12-05
Windows 10.0.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: UKWR07
Computer platform: DESKTOP
Secondary graphics devices.
NVIDIA Quadro P2200 (NVidia) Memory: 5GB, Driver date: 10-22-2020 (M-D-Y).
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
Intel® UHD Graphics P630 (Intel) Memory: 1GB, Driver date: 5-5-2020 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
ATTENTION:
No graphics device is being used. This is due to the driver having crashed on startup.
This can happen in Windows for any number of reasons, but unfortunately there really
isn’t anything Rhino can do about it.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: 5-5-2020
Driver Version: 27.20.100.8190
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: 1 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Users\ljacobs\AppData\Roaming\Grasshopper\Libraries\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.32.20340.21001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.32.20340.21001
I am getting the same error message at startup. I have tried looking at other forums for responses to this message but haven’t found anything other than updating graphic cards. Once I click “OK” I am still able to get into rhino and even render using the rhino render, but I can’t ViewCapturetoFile succesfully (it saves a black screen).
I just got a new work windows desktop computer today and have been having this issue with both rhino 6 and 7 installed. I remote in from a laptop also with windows and through a vpn. I have tried updating the graphics cards but both are 2020 versions and supposedly up to date.
Here is my system info:
Rhino 6 SR34 2021-2-3 (Rhino 6, 6.34.21034.07001, Git hash:master @ 2fec8130f097ca52a8bc9f334c3ed4a5921c5e30)
License type: Educational, build 2021-02-03
License details: Cloud Zoo. In use by: claassen.scott ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-J1PM2A2
NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 1-29-2020 (M-D-Y).
Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 4-11-2020 (M-D-Y).
ATTENTION:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 0.0
Driver Date: 4-11-2020
Driver Version: 26.20.100.8141
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.34.21034.7001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.34.21034.7001
Those drivers are NOT up to date. Windows itself also needs to be kept updated.
Hi i’m using Rhino7 and Rhino5 in Windows 10 (brand new laptop) and having the same issue:
i got the dialog box saing “Rhinoceros Graphic Driver Crashed” and suggesting to read the SystemInfo
This is it:
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Valutazione, build 2022-07-27
Expires on: 2022-11-30
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Unplugged [94% battery remaining] ~537 minutes left
Primary display and OpenGL: AMD Radeon PRO Graphics (AMD) Memory: 1GB, Driver date: 5-31-2022 (M-D-Y). OpenGL Ver: (null)
Integrated accelerated graphics device with 5 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 5-31-2022
Driver Version: 30.0.14038.7003
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: 256 x 16843008
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
Anyone knows how to fix this problem? Seems that unistalling and re-installing doesn’t work.
Thanks!
Well it seems that your driver isn’t very old but all those “nulls” and “n/as” indicate Rhino has no idea what video card you actually have…that’s not good. Maximum viewport size of 256 X 16843008? What is it?
Is Windows up to date? Try looking up the steps to THOROUGHLY uninstall your video driver before updating it?
Also, is your monitor connected through some kind of USB hub? They often have some kind of junky built-in “GPU” that’s absolutely not going to work.
@Samuele_Angeletti also reported the same problem at Rhinoceros Graphic Driver Crashed
