V8 crashing - PC Laptop
Hi there, I’m getting regular (sometimes multiple per day) crashes of Rhino.
When I get the “what were you doing when this happened” question, the answer is generally the same.
Nothing - Rhino was just left in the background. Most often it may be after my laptop went to sleep, if left overnight, etc. It rarely crashes when in use, but when I’m working on something else.
Hopefully the system info below is a help.
Thanks,
Adrian
Rhino 8 SR7 2024-4-30 (Rhino 8, 8.7.24121.13001, Git hash:master @ 44b9af795a5996a2a877659c9d5ef63b0da7ecfa)
License type: Commercial, build 2024-04-30
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [61% battery remaining] ~63 minutes left
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
> Integrated accelerated graphics device (shares primary device ports)
Secondary graphics devices.
DisplayLink USB Device (DisplayLink) Memory: 0MB, Driver date: 6-28-2023 (M-D-Y).
> External USB display device with 2 adapter port(s)
- Secondary monitor attached to adapter port 0
> External USB display device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.7.24121.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24121.13001
If you unplug the DisplayLink, do the crashes still occur?
Thanks @Helvetosaur
I’ll give that a trial, I have that set up at one office location only so I’ll try to see if the crashing is only at that location also. Could be something in that!
Adrian
Thanks again @Helvetosaur , have definitely had a lot less crashes since trialling that, so I’m not looking at alternative approaches to my second monitor.
Cheers,
Adrian
Multiple monitors need to be directly connected, they can’t go through some sort of external USB device, they are effectively their own–incredibly crappy–video cards. The ability to daisy-chain DisplayPort monitors probably works, if you’re one of the 5 people with a monitor that supports that.
