Get surface iso curves from openings
Hello everyone,
I’m currently working on generating iso curves from a surface while considering the surface openings to divide it into smaller pieces. The initial surface is shown below:
In the process of generating iso curves, I am accounting for all the corners of the openings, as illustrated here:
However, for the analysis I intend to conduct, I need to stop the iso curves when encountering an opening. Unfortunately, I haven’t found an easy way to achieve this. Specifically, I would like to remove the lines indicated in the image below:
I would appreciate any insights on a smart approach to address this issue.
Thanks in advance!
@Quan_Li @DanielPiker
Iso Curves.gh (5.8 KB)
Iso Curves Edited V0.gh (13.0 KB)
IsoCurve.ghuser (4.9 KB)
missing
That doesn’t appear to be used?
P.S. On second thought, I think colors are counter-productive in this case.
Iso Curves_2023Dec20a.gh (31.7 KB)
Hi @Quan_Li
I was not looking for random iso curves, maybe I did not explain myself. I just wanted to get the iso curves created by the openings but removing these curves cut by the holes
Hi @Joseph_Oster
This plugin is not used in the script.
Thank you very much for your answer, simple but efficient script. That’s is exactly what I wanted :slight_smile:
Just being curious, do you think that script can be applied in case of having different surfaces (floors with different Z coordinates) with openings inside of them?
Now that I removed ‘Flatten’ from the SrfSplit ‘C’ input, it should work?
Iso Curves_2023Dec20b.gh (18.0 KB)
P.S. Unfortunately, it’s not that simple is it… :thinking:
Well, I tried. Turns out it’s a baffling data tree problem and I didn’t have the time. So after finishing something else I had planned today, I took the easy way - an Anemone loop (white group) to do each holed surface one at a time. SO EASY :exclamation:
Iso Curves_2023Dec20d.gh (34.4 KB)
Thank you very much for spending your time on this @Joseph_Oster That’s exactly what I was looking for :slight_smile:
Regards
