You can use the api.scene.getData() call to get data from your models, see more details on this documentation page and the API reference. Also learn more about using our API with spreadsheets in following blog post, see section Batch Processing:
Hi Pavol,
Thanks for your answer.
I already read your links.
In the website it’s OK to get data with api.scene.getData().
But here I’m in Excel. So I don’t have api object.
Let say I’m in Postman. How to get outputs?
I use the “Session init and export request” API
Hi Olivia,
in order to access output data of your models using the Session init and export request of our backend API, please first configure an export in your Grasshopper model. You can use the ShapeDiverExportDownload component for that purpose, and somehow convert your data to text before feeding it into the component. Use txt as your file type. You can test your export using the export button that will show up in the viewer.
Once that works, use api.exports.get() of the viewer’s API to find the id of your export. Use this id when making the Session init and export request. Please also include the max_wait_time and set it to 10000 milliseconds (assuming that you have a PRO account). The reply to this request will contain a download link to the exported text file.
When running the Session init and export request from your local Postman app, you will be able to find some scripts explaining on how to locate the download link in the API response:
Towards the end of Q1 we plan to launch an SDK for our backend API as npm package, which will simplify the use the API and also allow you to access data outputs without using exports.
So do I understand correctly that there is currently no way to access the data outputs that you can get with api.scene.getData() in the viewer using the backend API unless you would export it as a file? I guess exporting as a .json file would make more sense, but would still be way more complicated than just getting an actual json response.
It’s actually quite easy to do in Integromat, where you don’t have to code anything. You could connect for example Google Sheets there with Shapediver. I will rework what I had to get the normal exports to also work with an export file, but of course it would be way easier. Not sure why its so easy with the javascript viewer api, but not possible with the backend api. I would have thought that getting the data would be even easier than getting the export file and therefore they would have done that first, but okay. I will let you know once I got the workaround working and share it here.
