I try to pull my cunstomizations with a script ( s. the code below), but this returns only the default settings.
Is it even possible? For aliases this is easily done with rs.AliasNames()
I tend to forget my settings when I pause using Rhino for some time.
import Rhino
for i in range(0,2000):
a = Rhino.ApplicationSettings.ShortcutKeySettings.GetMacro(Rhino.ApplicationSettings.ShortcutKey(i))
k = Rhino.ApplicationSettings.ShortcutKey(i)
if a:
print(i, a, k)
Thanks @dale,
I already figured that and probably wasn’t precise enough.
I have customizations in
1: Preferences → Aliases. Ich already got that with running rs.AliasNames(). I set-diff the
result of that method against a list of default aliases and voilá, get my custom ones. Problem solved.
2:Preferences → Commands → Customize… → Command Editor. In the macro library, one can set
a.: custom keyboard shortcuts, you can see them afterwards in keyboard shortcuts tab of the command editor, even copy them to clipboard.
b.: add custom macros to the macro library.
2a & 2b is what I’m trying to get. I have tried
ShortcutKeySettings.GetMacro(ShortcutKey)
Rhino.Commands.Command.GetCommandNames(True, True)
but only got defaults, not my commands.
