Get area in sqft
I am working on a building that is using inches, I have to calculate areas for rooms, the result of the area command are in square inch , but I need square feet , right now I use copy paste and a google transformation but this is pretty cumbersome. Is there a way to tell Rhino to use sq.ft. instead of sq.in. ?
thanks
Andreas
Hi Andreas, Area has a command line option for the units used in the report.
I had to use both metric and imperial dimensions on a previous project and at least for length dimensions it is possible to display an alternate unit below or next to the file unit.
For area dimensions this unfortunately doesn’t seem to work. :roll_eyes:
Hello - DimArea in V7 Beta does allow you to specify units in Properties.
thanks again pascal, this works for me, I forgot about the “-” option
